Minimum Bedroom Door Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 03:30 PM   #1
the Musigician
DangerMouse's Avatar
Minimum bedroom door size?
Is there a minimum size for a bedroom door?
DM
Old 10-04-2010, 06:40 PM   #2
Rewards Points: 5,336
For furniture movement, 30" would be the minimum.
Ron
Old 10-04-2010, 07:03 PM   #3
do yourself a favor and get 32" not 30. The extra 2" will make a difference.
wnabcptrNH is offline   Reply With Quote
Old 10-04-2010, 07:10 PM   #4
the Musigician
Found a spare 32", so I'm good! Thought I might have to reuse a 28", seemed a bit small.
Thanks!
DM
Old 10-04-2010, 09:38 PM   #5
Rewards Points: 1,092
Suggestion: If you are planning on living where you are building until death do you part, put in a 36" so you can wheel your way in/out.
Old 10-04-2010, 09:40 PM   #6
worth noting the majority of furniture is designed around a 30" door. 28s will not work with many chairs and couches.
racebum is offline   Reply With Quote
Old 10-04-2010, 10:07 PM   #7
jlhaslip's Avatar
Rewards Points: 2,812
Code for Bedrooms here is 28 " minimum if I remember correctly, but 32 " is far more common>
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-04-2010, 10:13 PM   #8
They make wheelchairs that fit thru a 28" door
So it depends upon how wide you are
Wife's friend had a elevator installed in their house for when they get older
I only install 32" doors for bedrooms
Last house had a 24" bedroom door
Old 10-05-2010, 05:22 AM   #9
Chicago, IL
Michael Thomas's Avatar
Experience has taught me to install a path with all 36" doors to the LR, DR and all bedrooms at my rental rehabs, otherwise tenants and movers WILL mess up door openings trying to move furniture.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-05-2010, 10:47 AM   #10
Good to know. I'll get the more aerodynamic 28" so I can pop wheelies through doorways and do laps around the perimeter.
Old 10-05-2010, 05:08 PM   #11
Framing Contractor
DM
Yes, there is everywhere. Are you under IRC? If you don't know what your under call your inspector and he will tell you.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-05-2010, 10:42 PM   #12
Rewards Points: 502
tell me about it. My house has a 6' high by 24" wide bathroom door.
I am both taller and wider.
forresth is offline   Reply With Quote
Old 10-06-2010, 12:45 PM   #13
Rewards Points: 590
My entry doors are only 32" I think people had smaller furniture in 1800. Of course, that doesn't explain why the door on the 1988 addition is only 32".
operagost is offline   Reply With Quote
Old 10-06-2010, 02:09 PM   #14
Almost every exterior door I have installed is 36"
One exception is the attic door onto the roof....only 34"
Door to the stairs to attic is also 36"
My existing bedroom/interior doors are only 30"
New 2nd floor bedroom door is 32"
New 2nd floor bathroom door is 36"
Walk in closet has a 32" door, then another 4' sliding door
Old 10-06-2010, 04:53 PM   #15
are these widths for rough-in framing, or finished width?
acerunner is offline   Reply With Quote
Convert bedroom into a bathroom? ChrisDIY Plumbing 10 04-28-2010 10:04 PM
Master bedroom placement near dining/living room EdieKay Remodeling 0 04-11-2010 06:48 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
Beautiful Bedroom Renovation! EdinDesign Project Showcase 11 10-03-2008 01:40 PM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
