08-02-2010, 11:38 AM
#1
the Musigician
Min. " between ceiling fan and wall?
What is the closest you can install a ceiling fan to a wall (corner in my case)?
Tip of blades to wall corner?
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
08-02-2010, 11:59 AM
#2
Xtreme DIY'r
Usually the blades will hit the sides before the corner
I'd maybe leave a few inches in case you want to install a bigger fan in the future
08-02-2010, 12:09 PM
#3
the Musigician
With 4' fan, it's 11"... with a 5' fan, it'd be less, of course. Just wondering if there's a minimum distance.
DM
08-02-2010, 12:19 PM
#4
Xtreme DIY'r
Not that I know of
My last house they installed one in the cathedral ceiling & it was hitting the ceiling
08-02-2010, 12:25 PM
#5
Totally screwed together
I would be concerned about wind turbulence thumping against the wall. If it's a bedroom, do you want to hear a helicopter hovering over you for 8 hours a night?
08-02-2010, 12:50 PM
#6
the Musigician
It'll hit a 90° edge, so I think that'd dissipate it enough, besides, I always have them pushing higher air down, winter and summer, it just seems to work better here. Also, it's in a back bedroom that will not be used as a bedroom much longer. It'll be my shop soon. Po)
If the wind noise bothers me, I'll turn up the music. It works fine in my truck that way... new noise? Turn up the radio! *grin*
DM
08-02-2010, 12:59 PM
#7
Moderator
You want the fan in the center of the room to optimize de-stratifying the room using the walls for air movement. Too close to the walls screws-up the air flow making it less efficient. http://housewares.about.com/od/cooli...anrotation.htm
Be safe, Gary
Clothes taking longer to dry?
08-02-2010, 01:04 PM
#8
the Musigician
It IS in the center of the room, the 'notch' is the elec. panel on one side and the walk-in closet on the other, hence the 90° jutting in towards the center of the room. Kind of like in the picture below. But gee.... thanks for the nomination! Po)
DM
08-02-2010, 01:36 PM
#9
the Musigician
Updated last post... added picture.
DM
08-02-2010, 02:06 PM
#10
Xtreme DIY'r
Yeah I'd add it there...maybe a little bit aways from the corner
But I'd leave enough room for a 54" fan
Seems that size is pretty common
Might look a little weird if its too close to that corner
08-02-2010, 02:39 PM
#11
the Musigician
It's not THAT close, the pic isn't to scale exactly... lol
A 5' would still leave 5" or 6", but I'll be installing a smaller 4' one, maybe even smaller, it's not a huge bedroom by any means. Po)
DM
08-02-2010, 02:43 PM
#12
the Musigician
I just try to see all possible scenarios.... like what if he (the elec. inspector, of course) says "What if someone wants a 5' years down the line? You need to move that box 12" to the right because the minimum distance for the largest fan allowed is ..."X" inches from fan blade tip to wall corner! Covering my behind is all. Po)
DM
08-02-2010, 02:47 PM
#13
Xtreme DIY'r
So with a 4' you'd be 18" from the corner
I'd say that's a decent distance
08-02-2010, 02:58 PM
#14
the Musigician
No, about 11" is all.... less than 12"... that's why I figured I'd better ask.
DM
08-02-2010, 03:45 PM
#15
Moderator
Check the diagonal line from the door corner to the opposite one, diagonally. Measure and match from the other corner opposite the closet insert to center.... Will that work? I believe height of fan is only thing on code. 12" minimum from blades to ceiling, 7' from blades to floor. Listed box, independent support for fans >70#.
Be safe, Gary
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
