Mighty Anvil - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2005, 02:31 PM   #1
Mighty Anvil
MA, I see flitch plates and beams mentioned on other forums. I know they are widly used in NJ. and was wondering if they make it a couple of hundred miles up the coast and what your opinion might be on using them. I am quite certain they are not used in the western states. Thanks you in advance. I enjoy your post even when I don't agree with them. HS
K2eoj is offline   Reply With Quote
Old 11-02-2005, 05:21 PM   #2
Flitch plates became rare when plywood box beams arrived and they disappeared when LVL's arrived. I've never used a flitch plate because I consider them too inefficient for use in a major beam (compared to a light steel beam) and I've never raised a window or door head that close to a ceiling in a residence.
I don't see anything wrong with the plates if there is not a more efficient design posssible.
Generally speaking for HEM-Fir #2 lumber in the 10 and 12 inch nominal height range:
a 1/4" thick flitch plate between 2x's is usually equivalent to double 1 3/4" LVL's of the same height.
a 1/2" thick flitch plate between 2x's is equivalent to double 1 3/4" LVL's that are about 1 1/2" taller.
I don't find that impressive enough to go to the trouble to order flitch plates cut to size when LVL's are available at the lumber yard and their capacity is so easily documented (stamped) by the manufacturer .... so I would only use them if I were in a jam and couldn't find another way to do it.
mighty anvil is offline   Reply With Quote
Old 11-02-2005, 07:58 PM   #3
[quote=mighty anvil]Flitch plates became rare when plywood box beams arrived and they disappeared when LVL's arrived.
I've never heard of a plywood box beam. Electricians have it made. One code book rules them all,... (except in seismic areas). HS.
Old 11-02-2005, 09:09 PM   #4
http://www.timber.org.au/NTEP/menu.asp?id=105
Old 11-03-2005, 12:40 AM   #5
Originally Posted by mighty anvil
Thanks, I got that one bookmarked.
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 03:14 PM
