Microwave Outside Back Exhaust - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 04:01 PM   #1
Microwave outside back exhaust
Hi all,
I am planing to install a new microwave which has the possibility of a back/top exhaust vent. I want to chose the back vent. Is it OK to do a straight vent to the outside, or does it need to go up first then out ?
Thanks !
simon templar is offline   Reply With Quote
Old 11-29-2010, 05:02 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Straight out the back is fine (assuming out back is an outside wall). That is the way my OTR is vented.
Coastal South Carolina
Old 11-29-2010, 09:58 PM   #3
Thanks.
Did you do the installation yourself ?
I need to use a flex bit in order to drill down to the basement and run a 20Amps line...
Old 12-02-2010, 10:39 PM   #4
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I installed mine back, down across under floor then out. As long as the equivalent lengths of duct don't exceed the rating you can go any direction. Straight out is simplest if you have exterior wall. Trick is if you have a stud in the way.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
microwave with exhaust bengrz Kitchen & Bath Remodeling 3 11-03-2010 06:12 PM
microwave with exhaust bengrz Appliances 1 10-13-2010 05:57 PM
Hood / Microwave Exhaust Vent, Wall question tameanaka Building & Construction 5 09-21-2010 03:44 PM
How do you reseat or put an over door back on??? wvoldwoman Appliances 3 04-19-2009 03:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
