Metallic Popping Sound - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 08:14 AM   #1
Hi all,
Have a question for you all. Our home is about 3 years old. Ever since we moved in we have heard a soft but audible metallic popping sound coming from inside our bedroom exterior wall. It seems to only happen when the temperature rises. I was wondering if perhaps the guys who bricked out house some how did not attach those metal strips that the bricks are attached to correctly. We are baffled and have gotten used to it but wanted to ask the panel of experts. As for asking the builder, well you guys know the answer to that one. One last tid bit, my home has been insulated with spray in foam. Not sure if that has anything to do with it or not.
Looking forward to hearing what you all think about this one.
Matt in Fort Worth
Motoman43 is offline   Reply With Quote
Old 09-06-2010, 08:19 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
any chance of an air duct being in the area you are hearing the sound?
Old 09-06-2010, 08:28 AM   #3
no the air ducts are in attic and the one closest to our bedroom comes into the ceiling. the air ducts in my attic air more like flexible hoses draped where ever needed. the sound is coming from the outside wall of the house. the sound reminds me of a tin can bending crushing sound. Thin metal.
Matt
Old 09-06-2010, 09:06 AM   #4
nap
You talking to me?
nap's Avatar
Is there any metal siding or trim in the area? Metal soffit maybe?
Old 09-06-2010, 10:04 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
maybe an old beer can
Tom Struble is offline   Reply With Quote
Old 09-06-2010, 10:04 AM   #6
Our home is completely foam insulated including the underside of the roof. There are no sofits for attic ventilation. Could one of those metal brick tags be causing the noise? It's weird it never goes away and is temperature related.
Old 09-06-2010, 10:07 AM   #7
hard to believe a brick tie would be heard thru all that foam
Old 09-06-2010, 10:20 AM   #8
nap
You talking to me?
nap's Avatar
I can't see how a brick tie would even make noise let alone something you would hear. Typically tinny sounds generated in a house are from sheet metal expanding and being restrained on the edges. The center then flexes inward or outward like an old oil can. A brick tie would be free to flex without such restraint so it would merely bend without the pop.
while the air ducts may be flex, those flex ducts are attached to something such as a boot which is made of tin. Since you have so much physically restrictive insulation, I can see where maybe the tin of a boot or some such ductwork piece might do the oil can thing.
when you say temp related, are you speaking of outside temp? Have you noticed any correlation between the sound and the AC coming on?
Old 09-06-2010, 10:24 AM   #9
do you have radiant heat in the floor?
Old 09-06-2010, 10:28 AM   #10
yes it seem like the outside air temp has a lot to do with the noise. no radiant heat floors.
Old 09-06-2010, 10:32 AM   #11
Rewards Points: 472
Originally Posted by Motoman43 View Post
Hi all,
Have a question for you all. Our home is about 3 years old. Ever since we moved in we have heard a soft but audible metallic popping sound coming from inside our bedroom exterior wall. It seems to only happen when the temperature rises. I was wondering if perhaps the guys who bricked out house some how did not attach those metal strips that the bricks are attached to correctly. We are baffled and have gotten used to it but wanted to ask the panel of experts. As for asking the builder, well you guys know the answer to that one. One last tid bit, my home has been insulated with spray in foam. Not sure if that has anything to do with it or not. Is their a garden hose bib their??
Matt in Fort Worth
go out side and see you can here it ? Like take a glass and put the bottom on the brick and track it down. Is this a solid brick wall? no window's ? I bet you will find where the loudest sound is. Now mark the spot and call the fellow that put up the wall and let him here the sound. Let him take it from their. I would guess a warrenty? If not How much $$$. Or live with it?
del schisler is offline   Reply With Quote
Old 09-06-2010, 11:21 AM   #12
need pics inside and out where you think the noise is comeing from
Old 09-06-2010, 12:26 PM   #13
nap
You talking to me?
nap's Avatar
time to get out the Partner saw!!!
Old 09-06-2010, 12:42 PM   #14
fabrk8r
fabrk8r's Avatar
What kind of soffit do you have? It wouldn't happen to be aluminum? How about gutter, it will expand and contract a great deal and sometimes will make noise is it is binding.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-06-2010, 01:35 PM   #15
oooo yea.... lets try that next
Hardwood floor makes popping sound jbessboro Flooring 5 01-26-2010 09:52 AM
Popping sound (loud) in hot water tank andrewd80 Plumbing 2 12-25-2009 05:38 PM
Loud intermittent Metallic sound from Heating Unit uy7473 HVAC 2 01-21-2009 04:15 PM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 12:27 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
