Metal Or Wood Cross Bridging - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 11:04 PM   #16
Registered User
Rewards Points: 5,520
Posts have been removed, please remember our first forum rule; "Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned." found in "Privacy Statement" or "Terms of Service" at the bottom of each page, thank you.
I think you are fine using the metal, rather than wood bridging. Some codes require solid blocking, depends on location. Solid is stronger, by far; http://www.ewpa.com/Archive/2004/jun/Paper_278.pdf
Any other questions we can help you with?
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
bbo (12-25-2012), Mijotter (01-11-2013)
Old 01-11-2013, 01:49 AM   #17
Rewards Points: 150
Thank you GBR and jasson that's all I needed I'm in the process of doing it now and it's going along easier than I thought, again thanks everyone.
Mijotter is offline   Reply With Quote
Tags
bridge , ceiling , joist , metal , sub floor
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 01:31 AM
buying metal cross braces Lturgeon Building & Construction 8 09-01-2009 03:55 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
