Metal Track Directly On Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 07:19 PM   #1
Metal track directly on concrete?
Hi
Im getting started on an outdoor kitchen and looking to clear up some confusion I'm having. I am framing the kitchen with metal track and studs.
Can I attach the track directly to the concrete or do I need have something in between like a piece of trex or other non-metallic barrier?
Thank you in advance for your suggestions.
Jawbreaker is offline   Reply With Quote
Old 06-28-2011, 07:43 PM   #2
Rewards Points: 5,336
Originally Posted by Jawbreaker View Post
Hi
I'd isolate the metal from the concrete.
What will be applied to the studs.
Ron
B. Franklin 1759
Old 06-29-2011, 01:51 AM   #3
Once the frame is completed I will cover it with hardie or cement board and that will be covered with tile on top and stucco every where else.
Old 06-29-2011, 11:29 AM   #4
Oh and I live in Sacramento, CA if climate is a deciding factor.
Old 06-29-2011, 01:18 PM   #5
I would use a composite material. It's 3/4" thick and you could put the metal track on that. This way no water will ever make contact with the metal.
Ron
B. Franklin 1759
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
