Metal Track - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 08:31 PM   #1
Question
metal track
Hello, please help
is it possible to use a metal stud as a track ?
Thank you in advance,
Hila
Hila is offline   Reply With Quote
Old 03-11-2013, 08:48 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,.... I don't think it'll support the weight of a train,....
A track for What,..??
Old 03-11-2013, 09:53 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
a track is formed to accept the studs, just a tad wider. a stud will not fit into another stud.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-11-2013, 10:00 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by Hila View Post
Hello, please help
Hila
if you really have to use a stud as a track you shoot down a stud as the track and add another stud to it (double it up) and screw it off both sides, then add L clips on top the double stud to attach the studs....
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
coupe (03-11-2013)
Old 03-19-2013, 11:09 PM   #5
yes you can I am a commercial framer, you just throw the track in like you would a stud. if its only one or two no big deal if you are framing a 80' wall out of track you better get some studs because they are less expensive
ubcguy89 is offline   Reply With Quote
Nothing to attach top track for metal studs wingman1153 Building & Construction 11 02-14-2013 05:58 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Track Lighting Installation - No Electricty tazmajazz Electrical 11 10-19-2009 11:09 AM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 11:31 PM
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 01:13 PM
