Metal Studs And Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 03:23 PM   #1
metal studs and drywall
which direction do i start the drywall. from the hard side or soft side of the studs
bullet proof is offline   Reply With Quote
Old 07-08-2011, 04:07 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Say huh !?!
XXX
Old 07-08-2011, 05:27 PM   #3
DIY staff
Rewards Points: 7,174
What??
Old 07-08-2011, 05:29 PM   #4
Rewards Points: 6,652
Come again?
Old 07-08-2011, 05:37 PM   #5
I had to scratch my head for a bit, but I think I understand the question. You are referring to the rigid side of the metal stud as opposed to the some what floppy open side of the stud? The question still is kinda silly though. You install the drywall the same way you would a wood stud. Then again maybe I am completely misunderstanding the question.
Stanchek is offline   Reply With Quote
Old 07-08-2011, 05:51 PM   #6
Rewards Points: 5,336
Sheetrock is applied to the narrow face of the stud, not to the wide face.
Ron
B. Franklin 1759
Old 07-09-2011, 05:35 PM   #7
Registered User
Rewards Points: 5,514
Always start on the open side, fig. 9, pp.14: http://gypsum.org/pdf/GA-216-2010.html
And, welcome to the forum!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Wookie (07-09-2011)
TV Mount on Metal Studs - What hardware is necessary? theproman23 Home Theater 6 03-02-2011 04:28 PM
Drywall & metal studs. meow571 Drywall & Plaster 1 11-05-2010 05:59 PM
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 01:32 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
