Metal Stud Max Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 03:53 PM   #1
Metal stud max Height
How High can I go with a 20 ga. metal stud?
BarBur is offline   Reply With Quote
Old 08-02-2011, 07:31 PM   #2
Too Old
http://www.awci.org/cd/pdfs/9002_b.pdf
14'4" for 20 gauge at 16" OC.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-02-2011, 07:39 PM   #3
remodeling pro
I would suggest a trip to your local commercial drywall supplier, who will be used to dealing with metal framing.
There are lots of variables to this answer besides just the height. Is this wall strictly to hang drywall on or will it support some type of display boards or storage shelves.? How much flexibility are you willing to tolerate? etc.
Design specs even differ from manufacturer to manufacturer of what appears to be the same product to the layman. Non obvious things like small differences in the depth of the return on the stud, and even the shape of the embossing on the metal affect it's strength. They are an engineered product, designed to yield maxinum strength with minimal material usage. Even the old way of refering to them as 20ga is no longer accurate,although still commonly used, as you will see that the thicknness of a 20 ga stud is less than the thickness of a 20ga piece of sheet metal.
troubleseeker is offline   Reply With Quote
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 07:55 PM
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
