Metal Stud Framing In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 07:12 PM   #1
Metal Stud Framing in Basement
I am trying to install metal stud framing in my basement. I wondered if I only need to put in screws on one side of the stud facing the center of basement? Or do I have to somehow pull the framing away from the wall and screw in the other side of the stud? Any suggestions, tips, help would be appreciated.
toolman327 is offline   Reply With Quote
Old 01-01-2009, 07:51 PM   #2
Rewards Points: 1,570
When I did mine with steel studs I don't recall trying to hit the back of the stud. The drywall attachment really solidifies the wall.
Try to shop around for steel stud insulation if you are insulating. May take a while to find it.
I used some of these kinds of clamps to hold the stud to the stud channel when screwing in the pan heads and it made it a bunch easier for me:
http://www.homedepot.com/webapp/wcs/...10000003+90401
Good luck with it!
B
bob22 is offline   Reply With Quote
Old 01-01-2009, 07:52 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
One side is fine.
Just make sure that you align your cut-outs (conduit holes) of the studs.
- Build Well -
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 05:24 PM
Basement Sofits - 2x2 or Metal framing whirly Building & Construction 41 01-29-2009 11:14 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
Metal framing for basement Drop Cieling? joliet_man@yahoo.com Carpentry 3 10-22-2008 02:16 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 11:54 AM
