Metal Siding And Roofing. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 07:48 AM   #1
metal siding and roofing.
i am thinking of metal siding and roofing for my cabin. should i put osb on then house wrap, then strap for metal or just wrap right on the studding. i have seen it done both ways.
leng is offline   Reply With Quote
Old 05-29-2011, 11:52 AM   #2
rock16's Avatar
What type of metal siding?
rock16 is offline   Reply With Quote
Old 05-29-2011, 05:38 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
you could do it either way but it's nice to have a 1/2'' of sheathing,giving you a nice flat surface to lay your window flashing details on
plus it makes window and door installations easier and you will have the correct wall thickness for standard units
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
leng (05-29-2011)
Old 05-29-2011, 11:21 PM   #4
Rewards Points: 1,092
osb is much more sensitive to water, if you ever get a leak. it tends to swell and get soft. also, i don't like having to screw anything into it; screws just don't anchor as well as w/ plywood.
The Following User Says Thank You to jklingel For This Useful Post:
leng (05-30-2011)
venting a range hood thru existing metal roof mycajah Roofing/Siding 1 03-22-2011 01:57 PM
siding a shed before roofing amakarevic Carpentry 5 01-30-2011 08:10 PM
what goes first roofing or siding ME4756@AOL.COM Roofing/Siding 6 09-22-2010 05:03 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 09:59 AM
