Metal Shed Require Vapour Barrier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 06:09 PM   #1
Solutions (handyman)
Rewards Points: 364
Metal shed require vapour barrier?
Does a metal shed or, in this case, a community hall, require a vapour barrier as you would in a wood structure. The metal is the outer skin and I see the inside is drywalled and some wood panels. If I were to remove them for up-grading purposes, I think I will find lacking insulation and no vapour barrier.
Again, should this type of building be treated as any other wood framed building?
Mark Harvey is offline   Reply With Quote
Old 01-07-2011, 06:25 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,632
Ayuh,.. In my experince, the vapor barrier is directly on the insulation...
About 2" of fiberglass, 'n a plastic backing...
vapour barrier HELP!!!!! 06GT General DIY Discussions 8 02-23-2010 08:01 AM
Drylock, Typar and Vapour barrier? fubar79 Building & Construction 5 11-06-2009 11:35 AM
Metal Shed Insulating Zen_Dog General DIY Discussions 10 08-22-2008 09:30 AM
Storage Loft in Metal Shed Traveller Building & Construction 6 09-30-2007 03:08 PM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing/Siding 21 06-18-2007 08:58 AM
