Metal Shed With Greentreated (AC2) Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 07:26 PM   #1
Metal shed with Greentreated (AC2) lumber
I have recently built a 12ft x 16ft shed out of 2 x 4 green treated lumber. I had a change in heart on the exterior, i was going to use wood and cover with vinyl siding, but now would like to use metal siding.
The question is : can I use the metal siding with green treated lumber ? or will i have to put a bubble insulation between the 2 ?
I was told that there would be a corrosion issue.
Thank You for your help !!
belprk1971 is offline   Reply With Quote
Old 11-04-2010, 06:01 AM   #2
I think you mean ACQ, and it can be very corrosive to metals. It can dissolve an uncoated steel nail in two months. You need to isolate it from other metals and use stainless of hot dip galvanized acrews/nails. How about vinyl siding??
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
floor foundation for a metal shed forever0082 Building & Construction 5 07-02-2010 09:08 AM
re: small metal shed foundation gramps416 Building & Construction 12 06-04-2010 03:25 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
