Metal Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 06:46 PM   #1
Metal roof
Building a new garage,Can i just install strapping on top of trusts and screw metal roofing to strapping or should i install 7/16 chipboard on top of trusts and then screw metal roof to chipboard? And should i put water and ice shield underneath metal roof in case of condensation.
Rejean is offline   Reply With Quote
Old 01-05-2012, 08:00 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I see people put metal over solid sheeting, but it sure seems like it would sweat alot. But if it's felted good...
The metal I have installed either went on metal purlins, or on residences, 1x3 skip sheeting, spaced the width of 2 1x3's (5").
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Tom Struble (01-05-2012)
Old 01-05-2012, 09:30 PM   #3
You don't need full sheathing, purlins will do just fine.
You don't need ice & water on an unheated garage ... and if you go with the purlins you'll have nothing to stick to, anyway.
Double-A is offline   Reply With Quote
The Following 2 Users Say Thank You to Double-A For This Useful Post:
titanoman (01-05-2012), Tom Struble (01-05-2012)
Old 01-05-2012, 11:15 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
you can get condensation whether it's heated or not
Tom Struble is offline   Reply With Quote
Old 01-05-2012, 11:27 PM   #5
Rewards Points: 14,312
Depends on what type metal roofing you installing.
Some of the roll locks require a soild roof.
Look on the manufactures web site.
If it's just the cheap stuff like what's at Lowes or HD then skip sheet will be fine.
Old 01-05-2012, 11:42 PM   #6
Disabled wood vet
titanoman's Avatar
Now that you mention it an old boss of mine had me run full plywood for a metal roof (I didn't do the metal). I thought it was wrong at the time. Maybe not.
We've also put solid sheeting under clay tile, which I thought was odd.
(on that job, the trusses were still 2' o/c, per manufacture specs. It turns out tile is actually lighter than comp., as they kind of bridge themselves from truss to truss).
If all else fails, after you've tried everything else, read the manufacturors instructions.
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 02:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
