Metal Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 08:37 PM   #1
metal roof
will 30# felt work as underlayment ,on top of 5/8 sheeting then felt then metal. or will the felt hold moisture under it and rot your plywood ?
townguy is offline   Reply With Quote
Old 10-11-2011, 10:35 PM   #2
I just put up a snap-lock standing seam metal roof and the metal roof manufacturer's specs called for 30# felt as an underlayment. 30# felt has been around for awhile and has a proven track record for use as an underlayment for many different types of roofing material.
If you're asking whether it's okay to lay 30# felt over wet sheeting then that's a different question. I wouldn't want to put felt over wet plywood. That's just me I don't know what the pros would say.
tomdor is offline   Reply With Quote
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 02:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
