Metal Post Support For Cedar 6X6? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 11:20 AM   #1
Metal post support for cedar 6X6?
Attaching Porch Post to Foundation
Looking for a metal post support like the user Earnie has on his deck. We had to replace a porch support, and I'd like it to be off the cement porch so it won't rot as quickly as the last post did. I'd prefer this style, so I don't immediately have to add trim around the bottom to conceal it. I've checked Home Depot/Lowes, but I've not had luck locating this specific style.
Thank you for reading this!
sarahphine is offline   Reply With Quote
Old 05-27-2013, 01:40 PM   #2
GBrackins's Avatar
Rewards Points: 2,086
Welcome to the Forum!
I'd recommend something along this line http://www.strongtie.com/products/co...A-ABU-ABW.asp#
can be simply attached with a anchor set into the foundation with epoxy. You want the end of the column up off the concrete so that it cannot wick moisture up into the column. End grain (bottom of column) is know to wick moisture which leads to rot in the wood column.
if you cannot locate these at the big box stores I'd recommend a local lumber yard.
Hope this helps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Installing an electrical recepticle on a basement structural support post PittsburghClint Electrical 8 12-18-2011 07:58 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 06:34 PM
Framing basement metal post kupalino Remodeling 11 01-02-2010 01:42 PM
Strongest metal support to wood joint. Fixitgeorge Carpentry 1 05-05-2009 05:38 PM
Hardwood and Metal Post Problem! moonweb Flooring 13 07-02-2008 03:12 PM
