-   -   Metal Lath (http://www.diychatroom.com/f19/metal-lath-59421/)
FUJIMO 12-16-2009 07:30 PM
Metal Lath
We are installing stone veneer around our fireplace. Everything I've read says when installing metal lath it should feel rough when running your hand from top to bottom. Our Lath is paper backed. Everything I've read about paper backed lath says when installing it start at the bottom right of the wall. The pictures I've seen show the paper overhanging on the top and right side of the lath. The problem is when I position the lath with the paper overhanging on the top and right it's smooth when running my hand across it going down the wall and rough when running my hand up the wall. Which way is correct.
Stillwerkin 12-16-2009 07:36 PM
I'd guess the roughness is to help hold the adhesive.
Gary in WA 12-16-2009 08:38 PM
Rough going down the wall with hand, page #4: http://www.gaf.com/Content/Documents/41002.pdf
Proper fasteners and spacing per code: http://www.robinsonbrick.com/product...stallGuide.pdf
Be safe, Gary
FUJIMO 12-16-2009 09:36 PM
Be safe, Gary
I'm really confused now.see page 3http://www.mtstone.com/resource/file...al_English.pdf
and
http://amico-lath.com/pdf/How%20to%2...tal%20Lath.pdf
beenthere 12-16-2009 09:47 PM
Fujimo.
I put your other thread in to the trash bin.
Please don't make duplicate threads across the forums, thank you.
Gary in WA 12-17-2009 03:27 PM
http://www.premierstone.net/installation.htm --- rough up
http://www.montanarockworks.com/thin...stallation.php -- cups up
http://www.countrystone.net.au/techn...all-guide.html -- same, method B
http://www.ryderrock.com/installation-instructions.php --- same
http://www.rock-itnaturalstone.com/p...structions.pdf --- cups up to hold the mortar.
Be safe, Gary
FUJIMO 12-17-2009 07:35 PM
Thanks GBR in WA I found another helpful page. (see page 13)http://www.mnlath-plaster.com/librar...Update2009.pdf
