Metal In Joists? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2008, 06:20 PM   #1
Metal in joists?
Hi;
I am working with an Zircon i500 in the metal mode, trying to locate BX cables beneath the floors of an upstairs room in my 80 year old wood frame home.
I cannot find the wiring, but I get a full scale, almost continuous reading along the entire length of the floor joists. I know that I am on the joists because I get these readings along lines that are 16" apart.
I know that the stud finder will pick up the nails in the joists and in studs, but I am perplexed as to why I get a continuous reading along the entire length.
Any ideas?
FW
fw2007 is offline   Reply With Quote
Old 03-28-2008, 07:53 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If it's 80 years old, I'd assume you are reading all of the nails in the floor boards which are close enough to look continuous to the finder.
Old 03-28-2008, 09:26 AM   #3
Thanks. I wouldn't have thought a continuous reading, but probably a lot more nails that I imagined.
FW
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
