Metal Joist Under Ceiling Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 11:17 AM   #1
Rewards Points: 79
Metal joist under ceiling drywall?
I am in the midst of installing a garage door opener in a condo. The ceiling is drywalled so I used a stud sensor to locate the joists to put the lag screws into to support the motor unit. When I found the joist I cut out a small area of drywall so I could get the screw in centered on the joist and it revealed galvanized metal about 1.5" wide with mesh on the edges. It's strange because in other parts of the garage I've hung other things and the joists were wood. Anyways, I put a small sheet metal screw in and tested it with some weight and the metal flexes down and is not rigid at all so it's not something I can tie a heavy garage door opener into.
Any idea what this metal stuff is? It is in-line with the other wood joists I know of. Only thing that is different is that it is about 1.5' from an area of the ceiling that is dropped down. I'm at a loss as to how I am going to mount the opener now.
thebigsee is offline   Reply With Quote
Old 12-02-2013, 11:27 AM   #2
Rewards Points: 1,002
Photo?
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Nailbags (12-02-2013)
Old 12-02-2013, 11:38 AM   #3
Rewards Points: 79
Originally Posted by Anti-wingnut View Post
Photo?
Sorry, don't have one, besides I doubt my camera could capture it well. Figured it out mostly by feeling around with my finger. Place was built in 1988 if that helps at all.
Old 12-02-2013, 11:38 AM   #4
cortell's Avatar
Rewards Points: 504
Fasten a 2x4 (flat side to ceiling), across the nearest two wood joists. Attach the garage door opener to that piece. Most of the load a garage door opener experiences is lateral, not vertical, so I believe this should work fine.
cortell is offline   Reply With Quote
Old 12-02-2013, 11:43 AM   #5
Rewards Points: 79
That's such a good idea that I am embarrassed I didn't think of it. Thank you.
The Following User Says Thank You to thebigsee For This Useful Post:
cortell (12-02-2013)
Old 12-02-2013, 12:06 PM   #6
cortell's Avatar
Rewards Points: 504
Sure thing. If you have wide joist spacing (>= 24"), and/or you're worried about the 2x4 bowing, use a 2x6 instead, or fasten a 2x4 vertically to the flat one, to form an L shape.
Old 12-02-2013, 12:12 PM   #7
Rewards Points: 79
Yes, the joists are 24" so that was a concern. Good advice!
Tags
ceiling , drywall , garage door opener , joists , metal
Placing drywall ceiling butt joints off joist. ppeetteerr Drywall & Plaster 19 10-21-2012 05:43 PM
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Mounting ceiling fan with old metal brace, need joist?? nimchimpski20 General DIY Discussions 3 11-09-2010 06:18 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
