Metal Framing Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 03:02 PM   #1
Metal framing help
I am planning on building a wall inside my loft and am required to use metal studs. Both the ceiling and floor are cement. How do i anchor the studs in the cement ceiling?
Thanks, Cory
cali canuck is offline   Reply With Quote
Old 10-23-2012, 03:08 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
either a ramset or a hammer drill with concrete nails
woodworkbykirk is offline   Reply With Quote
Old 10-23-2012, 03:49 PM   #3
Rewards Points: 454
Or tapcons
scottktmrider is offline   Reply With Quote
Old 10-24-2012, 08:34 PM   #4
Originally Posted by scottktmrider
Or tapcons
How close do the tap cons have to be from each other?
Old 10-24-2012, 09:06 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
For ease of use and quickness, ramset is the way to go. The bit you use for the tapcons will not go through the metal studs. So you need 2 bits and a screw gun to put them in.
Ramset,put the nail in place,hit it with the hammer,your done!
sublime2 is offline   Reply With Quote
Old 10-24-2012, 09:09 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
use steel track to hold the metal studs and space fasteners with 16 to 24" separation. pre drill the track and if you cut the studs tight to fit between the tracks you can anchor the top track later after the wall is filled in with studs and wedged between floor and ceiling...
pop chalk lines and anchor the bottom track first (laying out) and plumb all studs from the bottom track. sharpies and small C clamps will serve you well in your endeavor.
hand drive is offline   Reply With Quote
Old 10-27-2012, 12:52 PM   #7
Can i rent a ramset somewhere?
Old 10-27-2012, 12:54 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You can buy the manual handheld one from HD with nails and loads for about $30 bucks. WEAR ear and eye protection!
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 06:37 AM
Metal framing for basement Drop Cieling? joliet_man@yahoo.com Carpentry 3 10-22-2008 01:16 PM
Ramset for metal framing Mirimaggy Building & Construction 5 10-14-2008 10:19 AM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
