Old 10-28-2009, 12:08 PM   #1
Default Metal Framing - Ceiling Questions
I am building a soundproof music studio (a room within a room). This will be the 3rd one I have built but the first one using steel instead of wood. I'm very confused in this new world of metal framing.
I have a few questions. See attached sketch.
1) The ceiling will be separated from the room's main ceiling so the top metal plates won't be fastened to anything on top. Is this OK and not an abnormal practice?
2) The span of the ceiling is 12' x 18'. What is the best method for tying 10' metal joists together? Should I weld them together? Or use some kind of fastener?
3) Should I use a heavier gauge than 25? The ceiling will be loaded with 2 sheets of 3/4" drywall on each side - 2 on the interior and 2 on the exterior.
Any thoughts or advice are welcomed.
speedo is offline   Reply With Quote
More On This Topic
Now we need a way to seal the back to the picture frame itself. So the way I do this, I'm going to be using some metal fasteners, the easiest way to close up the two pieces of cardboard. And, before I do that, I'm going to have to make some points on the... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
Now we've measured four even points on the side going along the width of our plastic sheet, it's time to make the holes so we can go ahead and line it up to the opposite side and put our fasteners in. Now to make the hole, we want to get it close to the... Read More »
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
Framing basement metal post kupalino Carpentry 2 10-14-2009 10:20 PM
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 03:32 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 04:56 PM
metal roof questions tecate1987 Roofing 2 07-26-2008 05:20 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 09:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
