Metal Duck Work Under Home, Duck Work Is Directly Beneath Floor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 05:34 AM   #1
Metal Duck Work Under Home, Duck work is directly beneath floor.
Best way to insulate areas, joints, elbows where heat can escape in these sections that are joined from furnace to room vents. Best way to insulate and prevent this heat loss, causing more gas to heat furnace, heating duck work, loosing heat, while trying to heat 2500 sq. ft. home.
Best way to prevent the duck work having these weak areas, stop from loosing heat, lower gas bill?
miles1218 is offline   Reply With Quote
Old 11-28-2010, 06:55 AM   #2
There are caulk products for sealing duct joints available at home stores. There are also insulation products for insulating them, usually rigid insulation boards. If the space below is a basement, you may not want to fix leaks or insualte, since that heats the basement. If a crawlspace, the ducts should be insulated.
Old 11-28-2010, 11:34 AM   #3
I'm assuming this is metal duct work, not flexible tubes.
Seal air leaks at the seams using metallic duct tape (NOT the gray vinyl tape often called duct tape... it's good for almost everything in the world EXCEPT ducts).
If you really want to insulate the ducts, rectangular ducts are usually insulated using a rigid insulation board that has a foil outer surface, made for this purpose. There are fiberglass insulation wraps that can be used on round ductwork.
DIY_ing_Guy is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Poor Laminate Install - OK to Negotiate Bill After Work Complete? ralph99 Off Topic 13 10-21-2010 07:28 PM
Electric Baseboard Heater Is it O.k. to mount directly on Floor bltglt507 HVAC 4 12-05-2009 03:13 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
