Mechanical Vs Adhesive Fasteners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 07:24 PM   #1
Rewards Points: 260
Mechanical vs adhesive fasteners
Are adhesive fasteners superior to masonary bolts? I noticed the builder in my area was using masonary bolts to anchor the sole plates. Also, would I be able to drill a 5/8" hole using a regular drill?
bluefitness is offline   Reply With Quote
Old 11-24-2008, 07:33 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
A mechanical fastener, or mechanical-fastening, is always going to be superior to any adhesive.
- Build Well -
Old 11-24-2008, 08:49 PM   #3
Whatamess
Either purchase or rent a hammer drill to dill the holes. You can do it with a regular drill but it can be one hell of a job.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 11-24-2008, 10:20 PM   #4
Registered User
Termite's Avatar
For exterior walls, the bolts are a minimum code requirement. They must be 7" deep in the concrete.
As for drills, you must have a hammer drill and a masonry bit. You'd have better luck herding cats than using a conventional drill.
Old 11-25-2008, 08:42 AM   #5
Hammer drill will suffice, however, if you can get your hands on a rotary hammer drill, it will be even easier.
- Build Well -
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
How to remove adhesive from painted walls before painting buffnrie Painting 3 04-27-2008 01:14 AM
Adhesive of Slab nsb318 Flooring 1 02-28-2007 11:04 PM
Adhesive Removal SIE Flooring 4 07-05-2005 10:50 AM
