-   -   Measurments for purchased plans. (http://www.diychatroom.com/f19/measurments-purchased-plans-69218/)
Axe McGee 04-17-2010 08:40 AM
I bought some plans for a 16x20ft shed from a website. I get to the truss construction page and find it has measurements as fine as 21/64ths...? in wood working really?
So the measurements are for the angles of the truss' but it also has in there the angles in degrees. Is there a better way to work the dimension? Is to the 64th really necessary? If not what dim. can I take it to?
I'm almost done with this project, in between college, baby, and wife. It has taken me about 5 days if i total all my time up, working by myself. I 'll get some photos posted when I'm done.
vsheetz 04-17-2010 10:56 AM
If the plan is truly describing a truss structure, the intention is for the information to be provided to a company who builds the trusses for you. They are then delivered onsite and you erect them on the walls. Having done both stick building and trusses, trusses are a great way to go, IMHO. And I think you will find the pricing of having them built is reasonable.
Big Bob 04-17-2010 11:37 AM
OP, if you can advise the description of gussett plates (how truss webs are joined) on your plans we can advise if this is DIY or a truss plant layout.:thumbsup:
Know that engineered trusses are built to tight dementions to transfer loads properly.:yes:
If you have permit and inspections..this could be very important to you.:whistling2::yes:
Axe McGee 04-17-2010 08:58 PM
They have on the plans to cut the gusset plates out of 1/2" plywood to the dimm. they specify. There are 4 diffrent types of gusset plates they are showing being used on the truss set up.
Sadly when I purchased the lumber for this I purchased enough for the trusses, I should have thought ahead and had them prefabed and delivered...
The prefab truss idea actually makes sense now, with the close tolerance they are showing.
vsheetz 04-17-2010 09:19 PM
Maybe some ideas that will help. Does the place you purchased lumber also do trusses - maybe they will swap and provide you a credit. Sell the lumber on Craigslist. See if a truss maker will do a swap.
Big Bob 04-17-2010 09:29 PM
Sounds like a DIY plan... try playing with some scrap wood... see if you can get the right angle.. once you get it right..you will have a templet to work from... try making a truss.. odds are you will do fine...as long as they are all the same..and tight... your shed roof will look great. :thumbsup:
or toss the plans and stick build the roof frameing..
or you could have a truss plant make some... tell them you want gable trusses for a 16 X 20 with ( advise desired roof pitch) they will fix you up..:)
troubleseeker 04-17-2010 10:22 PM
Only in the mind of the computer :laughing:. These dimensions are automatically calculated by the CAD program the designer was using.
I always get a good chuckle every time I review a set of plans for the first time and see 1/64" dimensions:yes:. Since your tape measure in 1/16" increments, anything smaller than this is meaningless, unless you plan on building with an enginer's scale.
It is a pretty big leap of faith to extend an angle measured with a protractor out to half of a 16' truss, so you will need to calculate the height at the centerline of the truss. This can be done with a construction calculator...or makes a good exercise for a family member who is in high school geometry or trig.
Axe McGee 04-18-2010 07:56 AM
thanks for the help gang. I'm gonna go out this afternoon and ponder what my next move is.
Like I said I'll get some photos posted.
