Maximum Span Without Intermediate Support Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 09:16 AM   #1
Maximum span without intermediate support question
Hi all, first post here as I couldn't find the info anywhere else. Basically, I'm building a patio cover that will be tied into my existing house roof. The cover will be just under 15 feet long. I will be using light gauge corrugated metal sheathing, so the roof cover itself will be very lightweight. My question is this: Can I use 2X6's for rafters without any middle support(to prevent sag), or will I have to go with 2X8's. The roof will slope around 4 inches over the course of the entire span. Any help is greatly appreciated!!
yaryar is offline   Reply With Quote
Old 11-11-2008, 06:08 PM   #2
Doing This Way Too Long
Rewards Points: 532
Your geographic location would be helpful due to snow load etc. Regardless, 15 foot span with 2x6 is a big NO. I believe 12' is maximum for even 2x8 16" oc here. Your local bldg dept would be able to tell you what minimum width and spacing would be for 15'.
You are planning on putting corrugated panels on basically a flat roof which also is not very wise planning. May want to think through your design a little more before you commence construction.
OldNBroken is offline   Reply With Quote
Old 11-11-2008, 10:08 PM   #3
I moved your thread topic to a more appropriate forum for your answers.
Ed
Ed the Roofer is offline   Reply With Quote
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 07:32 PM
Paralam support question.... dcd22 Building & Construction 4 07-19-2007 06:41 AM
Hello People, New Here and have a question Hillman Building & Construction 4 02-21-2007 05:16 PM
