Maximum Shed Rafter Length Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 02:58 PM   #1
Maximum shed rafter length span
So, I am attempting to build a cabin with a shed-style roof.
I intend to build the cabin to a size of 16'x 36'.
The walls are 2x6 with a double top plate of course, the floor 2x8 with 3/4 inch plywood sheathing, and the rafters shall be 2x10, to allow for r-35 insulation.
What I need to know is what is the maximum length the 2x10 rafter can span without the need for support mid-span.
So, the question is: can a shed style roof with 2x10 rafters span the 16 foot wide structure without the need for any supports in the middle?
wwsteel7 is offline   Reply With Quote
Old 01-18-2012, 03:03 PM   #2
Rewards Points: 2,210
Depends on pitch of roof and roof/snow load.
Make sure you have air flow above your insulation in the roof. Has to come in the bottom and go out the top.
mae-ling is offline   Reply With Quote
Old 01-18-2012, 03:06 PM   #3
the pitch is 3-12, and the roof load should be 40 psf
Old 01-18-2012, 03:16 PM   #4
Here is a simplified span table. http://www.wclib.org/pdfs/SimpSpanTbls.pdf
I would go with no less then #2 fir, prefer #1 fir. Watch out for knots that might cause a weak point.
Old 01-18-2012, 07:44 PM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I would think you could span that far with 2x10 but you should see what local codes call for.
titanoman is offline   Reply With Quote
Old 01-18-2012, 08:37 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Try THIS link.
Andy.
AndyGump is offline   Reply With Quote
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed style porch rafter span and spacing sjjacks Building & Construction 3 05-05-2009 07:17 PM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 05:12 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
