Maximum Diameter Holes In 2x4 Interior Walls. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 12:24 PM   #1
the Musigician
DangerMouse's Avatar
Maximum diameter holes in 2x4 interior walls.
I need to run plumbing through a 2x4 wall for 5' or so, am I OK drilling a 2" hole through them to allow room for foam noodles as well as the tubes?
Thanks!
DM
Old 08-23-2010, 12:30 PM   #2
Rewards Points: 37
1 3/8" in single 2x4 stud, and 2" if studs are doubled if i remember correctly..
jarleifvaagen is offline   Reply With Quote
Old 08-23-2010, 12:33 PM   #3
Rewards Points: 37
i think you need 5/8" to the edge from the hole, and the hole can't exceed 40% of stud depth in single 2x4, 50% in doubled 2x4..
Old 08-23-2010, 12:38 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I always thought you could go larger if stud was on non load-bearing wall.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-23-2010, 12:59 PM   #5
Rewards Points: 37
that's very possible..I would check with local building codes to be sure..I base my information from one of my mentors which may or may not be correct on the issue..
if you take a 2" hole out of a 3,5" stud, there's not a whole lot left on either side..if you then offset the hole a little by accident it'll be even less on the one side... I cringe every time i put a 3/4" hole through a 2x4... lol...then again i tend to overdo things... one of my favorite terms while building something is "This should hold an elephant!".. haha
Old 08-23-2010, 01:36 PM   #6
the Musigician
There will be a wooden wall on one side (back of tub) if that makes a difference. Drywall on the other side should be sufficient?
DM
Old 08-23-2010, 02:12 PM   #7
Registered User
Rewards Points: 5,498
http://docs.google.com/viewer?a=v&q=...b6CBPjc714bhbA
Ask locally also...
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
DangerMouse (08-23-2010)
Old 08-23-2010, 02:15 PM   #8
Old School
Willie T's Avatar
This is kind of old. It’s an excerpt from the 1994 Uniform Building Code, the International Conference of Building Officials. But I think the numbers are still the same today.
Sec. 2326.11.10. Bored Holes. A hole not greater in diameter than 40 percent of the stud width may be bored in any wood stud. Bored holes not greater than 60 percent of the width of the stud are permitted in nonbearing partitions or in any wall where each bored stud is doubled, provided not more than two successive doubled studs are so bored.
This drawing shows 2x6 walls, but you can apply the math to 2x4's if you need to. (A 2x4 is about 63.64 % of a 2x6...... Multiply any number shown here by .6364, and you should be in safe territory.) That means the 2.25" hole shown in the upper righthand example would convert to a hole 1.4319 in a 2x4. That's a little less than 1-7/16".)
But if you are going for the 60% number, you're safe with 2.1..... or a light 2-1/8". (That's a 2" hole wallowed out a tiny bit.)
Of course all this is assuming the code is still the same today as it was way back then. And if you have a stickler for an inspector, it never hurts to drill a slightly smaller hole than actually allowed. Gary shows newer and tighter codes, so I wouldn't push it.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 08-23-2010, 03:02 PM   #9
the Musigician
Thanks! That's very helpful! I figure I already drilled the holes, so if the framing inspector has a problem, I can always add 2x4s sideways centered in-between the existing studs, alternating edges front to back, and just keep what I have. I should probably just do that anyways since I'm pretty sure he'll say something.....
DM
Old 08-23-2010, 03:12 PM   #10
the Musigician
Something like this should be accepted if the holes are too big, yes?
Thanks!
DM
Old 08-24-2010, 11:46 PM   #11
Rewards Points: 1,092
(I guess I nuked my last reply, so....) Looks like you had room to hang the tubes from the 2x4s, no? The "sideways" 2x4 may do more good if it is snugged against the "normal, holy(play on words there, guys)" one and nailed. Each can brace the other against deflection in their weak direction. Gary?
The Following User Says Thank You to jklingel For This Useful Post:
Gary in WA (08-25-2010)
Old 08-25-2010, 08:40 AM   #12
the Musigician
Good idea....
DM
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 06:20 PM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 01:05 PM
Interior: Preserving Installation Screw Holes During Skim coating? Lovegasoline Building & Construction 4 09-29-2009 03:03 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
