Max Span For 2 2x8 For A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 12:23 PM   #1
Max span for 2 2x8 for a deck
Needing to span 14' 3" for a deck at 12 on center. Don't have room for 2x10 and a single 2x8 spans 13' 8" Wanting to know if 2 2x8 still spaced at 12 on center would be safe for wet service with 40 psf live load 10psf deal load?
and if it is ok, what would be the max load on it.
Davengerguy is offline   Reply With Quote
Old 10-30-2012, 12:26 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
hand drive is offline   Reply With Quote
Old 10-30-2012, 12:45 PM   #3
thanks for the info, but I still do not see a max span for 2 2x8 used as a floor joist. I see one listed for a beam, but not a floor joist.
Old 10-30-2012, 02:09 PM   #4
AHH, SPANS!!!
you are getting into specialized framing that is not listed in code books, it seems that if your single 2x8 span calc is a few inches short then sistering a joist on will increase span capacity and be ok.
Old 10-30-2012, 02:22 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
what grade and species of wood are you using? is it preservative treated (at mill)?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-30-2012, 02:26 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
or add a second beam mid span
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
kwikfishron (10-30-2012)
Old 10-30-2012, 03:58 PM   #7
It is treated wood.
Grade is No2
I am not with the lumber right now but I belive it is Yellow pine.
Old 10-30-2012, 05:15 PM   #8
GBrackins's Avatar
using doubled 2x8 pressure treated #2 southern pine at 12" o.c. will provide you around L/600 live load deflection which will exceed the 2009 International Residential Code requirement of L/360.
here is the wet service span chart of southern pine joists. if you wanted you could order machine stress rated lumber and be in compliance with 2x8 #2 at 12" o.c.
the issue may be your building inspector. there are no span tables I am aware of that provide for double floor joists in a wet service condition. the inspector would be within their right to require a sign off from a professional engineer to demonstrate compliance with the code requirements.
Good luck!
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
woodworkbykirk (10-30-2012)
Old 10-30-2012, 07:06 PM   #9
GBrackins's Avatar
you could also configure your deck into a free standing deck as outline in the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide" as linked by harddrive above.
this would reduce your joist spans
another option .....
Gary
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 11:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
