Max Joist Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 04:46 PM   #1
gkaro's Avatar
max joist span
Hi all.
Plans call for 2x10 spruce lumber at 12"oc. Total length is 17 ft supported on a ledger board on one side, and on a triple beam at the other end.
They are installed but it seems to me that they are a bit small for this run length...
Thoughts?
gkaro is offline   Reply With Quote
Old 01-12-2012, 05:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by gkaro View Post
Hi all.
Thoughts?
what is the load?
Old 01-12-2012, 05:08 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
17' seems overspanned. If you put a beam at midspan you can go up to 16" o/c.
Check with your local building department for local codes.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-12-2012, 05:31 PM   #4
Experienced
Jackofall1's Avatar
Hi all.
Thoughts?
http://www.awc.org/pdf/STJR_2012.pdf
Its all a matter of how much deflection and bounce you are willing to tolerate
Mark
Old 01-12-2012, 06:11 PM   #5
gkaro's Avatar
It's actually right from the city. Does it make a difference if it for a roof or a livable floor? I assumed they are the same due to snow load.
Old 01-12-2012, 06:16 PM   #6
Disabled wood vet
titanoman's Avatar
They'll probably be very different.
Old 01-12-2012, 06:20 PM   #7
gkaro's Avatar
Oh...best guess....which would need stronger lumber?
Old 01-12-2012, 06:31 PM   #8
Disabled wood vet
titanoman's Avatar
Uh...which is heavier, the roof
full of snow and wind or a floor full of furniture and stuff (live load)?
That's a stupid answer. That's what the planning and building department are for.
Old 01-12-2012, 06:36 PM   #9
robertcdf's Avatar
Floors usually require a higher loading than roofs, but not always. I knew an area that had the following loading requirements: Roof: 10DL 30LL House Floor: 10DL 40LL Deck: 10DL 50LL.
robertcdf is offline   Reply With Quote
Old 01-12-2012, 06:53 PM   #10
Civil Engineer
Rewards Points: 4,698
A learned discussion on allowable span, and you haven't told us where you live, what code you are under, or if there are any unusual loads on your span. For all we know, your joists are holding up air. Course you do indicate that the lumber was sized on the plans, so are you wondering if the designer made an error?
If joists are sized according to code, they will be sized for the more restrictive of two conditions. Condition one is the strength of the joist. Condition two is the allowable deflection. These conditions are set out in the code, and the allowable deflection criteria is very different for a floor than for a roof. And the loads for a floor are normally very different than the loads for a roof.
Daniel Holzman is online now   Reply With Quote
Old 01-12-2012, 07:28 PM   #11
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
From IRC 2009.
I have no idea if this actually pertains to your situation but it may.
Andy.
AndyGump is offline   Reply With Quote
Old 01-12-2012, 08:31 PM   #12
Rewards Points: 944
I was going to say that one used to be able to span 16' with a 2x10, fir, 12' with a 2x8. Now the spans have been shortened because of the quality of the wood.
So I was going to say you would be quite comfortable with 17' and 12" spacing.
But there you have the chart right in front of you and it says 17-9. That is for spruce, which has to be the worst.
If you want to stiffen it up some more, then I would suggest putting in 2 or even 3 sets of solid wood blocking. Then you will really have something.
cleveman is offline   Reply With Quote
Old 01-12-2012, 10:41 PM   #13
gkaro's Avatar
I am in Canada. The joists that I am referring to are for a flat roof on a one floor addition. I instructed the designer to size everything so that a second floor could be added on top in the future....possibly. Then the roof would become a floor.
The permit was not done for a second floor so the entire plans look like overkill for just the first floor. I'm just questioning now if the designer actually called the 2x10s correctly for the second floor???
Old 01-12-2012, 10:48 PM   #14
Rewards Points: 2,212
The addition of a second floor does not affect the size of the first floor joists. 2x10 fir at 12" o/c sound ok for 17' span. Probably calls for some blocking or cross bridging too would be my guess.
You may want to look into TGI's (I joists) could probably go 16" o/c
mae-ling is offline   Reply With Quote
Old 01-12-2012, 10:49 PM   #15
gkaro's Avatar
Mae ling. Thanks for your reply. I corrected my post. Please reread.
Joist span question simonb Building & Construction 17 08-29-2011 10:45 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
