Max Hole Size On 2x4 Top And Bottom Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 03:04 PM   #1
Rewards Points: 640
max hole size on 2x4 top and bottom plate
I need to run some DWV vent through 2x4 walls that are non-load bearing walls.. what is the max hole size for this situation? just trying to figure out if i can retro fit 1 1/2 or 2" PVC vertically through that space...thanks!
BlueBSH is offline   Reply With Quote
Old 04-08-2012, 03:42 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by IPC
F101.3 Bored holes. A hole not greater in diameter than 40
per-cent of the stud width is permitted to be bored in any wood
stud. Bored holes not greater than 60 percent of the width of the
stud is permitted in non-bearing
partitions or in any wall where
each bored stud is doubled, provided not more than two such
successive doubled studs are so bored. In no case shall the edge
of the bored hole be nearer than 0.625 inch (15.9 mm) to the
edge of the stud. Bored holes shall not be located at the same
section of stud as a cut or notch.
3.5 x 60% = 2.1"
3.5 x 40% = 1.4"
Old 04-08-2012, 03:50 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Looks like your good to go!
sublime2 is offline   Reply With Quote
Old 04-08-2012, 05:20 PM   #4
Rewards Points: 192
Just a question. The 60%/40% is that for vertical studs? I beleive the OP is boring the top plate and bottom plate. Could you completely bore the top and bottom plate in a non load bearing wall?
bcgfdc3 is offline   Reply With Quote
Old 04-08-2012, 05:40 PM   #5
Rewards Points: 640
thats actually one of the reasons i was asking.. ive seen examples online where they cut the plates out completely and just put nail guards across.. but wasn't sure if that is allowed now or not
Old 04-08-2012, 06:09 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The calculation applys be it vertical or horizontal. Metal plates are recommended .
Old 04-08-2012, 07:01 PM   #7
In a little over my head
Rewards Points: 706
If it wasn't allowed, how would any bathrooms be vented?
ratherbefishing is offline   Reply With Quote
Old 04-08-2012, 11:19 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
This should help.
Taken from the 2009 IRC.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
PaliBob (04-08-2012)
Old 04-09-2012, 01:14 PM   #9
Rewards Points: 150
Assuming the framing is done correctly, it is not uncommon to see a section of top or bottom plate completely cut out even in a load bearing wall. Happens all the time.
psilva8 is offline   Reply With Quote
Old 04-09-2012, 02:42 PM   #10
Rewards Points: 640
Originally Posted by AndyGump View Post
This should help.
Andy.
so... this is allowed if im reading the picture right as long as its strapped and fireblocked
