Max Hole In 2x8 Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 07:09 PM   #1
max hole in 2x8 floor joist
Hi Guys/Gals,
I'm currently building a new home and need too install a cable/telephone "raceway" in the ceiling in order to be able to freely pull cable/telephone wires. This is too allow me to easily upgrade or replace damaged cables from the outside of my home were the Cable/Telephone providers place there wires too the middle of my home were I have all my cable/telephone termination points are located.
My Question is I would like to install a 3/4 inch raceway in the ceiling and I have to drill holes through all of my 2x8 floor joists in my home......what is the max hole size I can drill safely? I only need a 1 inch hole and I live in Canada if that matters.
Thanks,
Steve
nfslane is offline   Reply With Quote
Old 06-23-2010, 08:03 PM   #2
Registered User
Rewards Points: 5,498
Page #31: http://books.google.com/books?id=iwS...num=3#PPA32,M1
Check with your local Inspector, they may have something like this: http://www.ladbs.org/faq/info%20bull...20notching.pdf
Be safe, Gary
Old 06-24-2010, 04:02 PM   #3
Thanks Gary, in everything and everywhere I have been reading. I'll be safe with a 1 1/4" and keep it towards the ends of the joists not the middle.
Thanks for your help,
Steve
Be safe, Gary
Old 06-24-2010, 04:32 PM   #4
Totally screwed together
Actually, the middle of the joist is best, not the ends. In the middle of the joist, the forces are concentrated on the top and bottom faces. Think of it like an I beam.
xxPaulCPxx is offline   Reply With Quote
Old 06-24-2010, 04:53 PM   #5
Old School
Willie T's Avatar
This makes it more fun to learn.....
max hole in 2x8 floor joist-20000701_how_a_house_works_page002img001_size2.jpg
Willie T
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
