-   -   Material for capillary break under PT Framing in basement (http://www.diychatroom.com/f19/material-capillary-break-under-pt-framing-basement-41918/)
jeeper 04-06-2009 01:53 PM
What does everyone recommend as a capillary break under the PT wood when framing subgrade basement walls? should I use EPS? Thanks in advance.
Bob Mariani 04-06-2009 02:18 PM
Foundation sill insulation (foam) is fine.
Termite 04-06-2009 02:44 PM
Yup, foam sillsealer is the way to go.
jeeper 04-06-2009 03:03 PM
Thank s for the replies. If figured that is what I needed I checked the big building stores for what I needed online and they don't carry sill gasket or anything but the Canadian site did. Anyway I head over and see if they got the nice roll of FoamSealR sill foam or equiv. Thanks again
Bob Mariani 04-06-2009 05:09 PM
Use the rest to cut up and place on the inside of all your electrical plates on the exterior walls. This is another large energy waster.
Gary in WA 04-06-2009 08:26 PM
Do not use sill sealer on outlet, switch covers.
Polyethylene sill sealer is flammable.
flash point >320 F. melting point - 220 F.
"Store in a cool, well ventilated area away from excessive heat and sources of ignition." Protecto manufacturer
So I just lit some with a match, instant 2" flame; then I lit a store-bought foam outlet cover, no flame- just kept shrinking to nothing. No liability. I now wonder if my wall paint is flammable............. Be safe, GBR
jomama45 04-06-2009 08:33 PM
Ther's literally only one way to find out!:eek:
Bob Mariani 04-07-2009 06:07 AM
Will consider this. Very good point. While contracting in CO during the 80's energy crisis the state had state certified energy saving classes. this was a tip by the government instructors. I completely forgot that I have since learned the government cannot do anything right. I have only two of the sill foam ones in my house and the rest are the ones from an electrical supply house. Guess I should change those two.
