Matching Texture - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 01:25 PM   #1
Matching Texture
I need to match this texture on a ceiling. There are multiple places that need patches and I am not sure how to match it. Any advice, thought, etc would be helpful.
Thanks!
MatthewC is offline   Reply With Quote
Old 01-24-2011, 04:03 PM   #2
Rewards Points: 5,336
Reproducing a textured ceiling is a very hard thing to do. If you want to try, get yourself some examples of texture that's close to yours and practice on some sheetrock until you get it close(or give up)
You might check out You Tube videos or "how to" videos over the web.
Ron
Old 01-24-2011, 04:10 PM   #3
Rewards Points: 4,806
its a knockdown finish ( friend of mine calls it ' tuscan trowel ' so he can charge more ) i'm not all that bad at patching but, to match an original finish, usually the original guy has to do it,,, you'll always notice your work compared to his,,, fwiw, hire a pro - i do !
Old 01-25-2011, 09:01 AM   #4
SteelToes's Avatar
Rewards Points: 150
knock me
Yes indeed that is a tuscan trowel deluxe technique , very difficult to match.
I'd say try using 1" nap roller and touscan down after 5 min...
Practice on a scrap piece of drywall and try using couple different nap sizes.
That is definitely rolled on texture not sprayed so it's all about finding a same nap, same compound, same knock down timing and the same angle...
Good luck
George
SteelToes is offline   Reply With Quote
Old 01-26-2011, 04:52 PM   #5
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
I think i am going to totally disagree with the last to posts.
I believe it was toweld on like stucco. regular mud and then it was flattend after a little drytime.
The way it is in rows is a good indication that it was used with a trowel.
It is a very thick texture but oh VERY EASY to match.
get a drywall knife or a handheld stucco trowel. and just practice putting it on in straight lines. let it sit and then flatten it out.
Im an expert. i can match anything
how to remove popcorn
stoner529 is offline   Reply With Quote
Matching drywall ceiling texture roger35768 Drywall & Plaster 10 10-15-2012 08:23 AM
Need help matching existing texture mud99 Drywall & Plaster 8 06-22-2010 09:37 PM
Matching texture? Dbn107 Drywall & Plaster 3 03-24-2010 07:13 AM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
