#1 |
Matching Room Add Foundation with Main House
What is the best way to match or alter a concrete room addition slab that is 6 inches lower than the main house slab, so that both areas will have the same base floor height (resulting in a seamless floor transition)?
#2 |
Concrete option: Form, lay down 2" of stone if desired, and fill with concrete to match.
Wood Option: lay down isolation strips (plastic or sill seal) under p.t. wood joists at 16" o.c. (2x6 at 5-1/2" and 3/4" plywood will make 6-1/4" total). Floor will be 1/4" proud with this setup, but that's no different than the transition of alot of floor finishes Alternative Option: 2" of rigid foam, 3-1/2" 2x4 joists laid right on insulation at 16" o.c., 3/4" plwyood subfloor sheathing. Floor will be 1/4" proud with this setup, but that's no different than the transition of alot of floor finishes
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by AGWhitehouse; 07-26-2011 at 12:31 PM. |
| The Following User Says Thank You to AGWhitehouse For This Useful Post: | rweklund (07-26-2011) |
#3 | |
Matching Room Add Foundation with Main HouseQuote:
Built up new slab to meet the existing house's floor level minus 3/4" to extend existing hardwood flooring. We went with the concrete option but the other options mentioned by AG I also considered and would work as well. |
#4 |
Thank you for your post. Its nice to know it can be done that way. BTW, did you use any stone/gravel for your base or did you go with 100% premixed concrete? Secondly, did you have to deal with any exterior doorways? I guess you could just make the doors smaller or raise them up via re-framing........
#5 | |
And YES, have an exterior doorway as well. But the exterior doorway will be gone once it's framed in so it won't be an issue for us. I would think one could just raise the door as long as it's not a huge difference. |
| Tags |
construction, foundation, slab ![]() |
| Display Modes | |
| Wiring Size Calculations for New Service | CorinthWest | Electrical | 7 | 12-07-2010 12:36 PM |
| Main Floor Reno Ideas Help PLz | **FYE** | Remodeling | 1 | 10-20-2010 06:40 PM |
| Can a roof vent identify where my main sewer line exits the house? | YerDugliness | Plumbing | 8 | 01-26-2010 05:13 PM |
| Attic Fan AND Whole House Fan | PapaGnome | HVAC | 6 | 02-15-2009 03:28 PM |
