Matching Mortar? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2007, 10:25 AM   #1
Rewards Points: 152
Matching Mortar?
Hello,
I have a 60 yr old brick home that I put an addition on. I want to try and match the existing mortar. What is the best way to do this?
Thanks!
sandyman720 is offline   Reply With Quote
Old 11-12-2007, 11:58 AM   #2
Rewards Points: 1,232
With squinty eyes.
The problem with "matching" mortar is that if you make the fresh mortar match, it probably won't when it ages and vice-versa.
Tscarborough is offline   Reply With Quote
Old 11-12-2007, 12:05 PM   #3
Post some pics if you can, good close up color of mortar.
some old tricks like adding oatmeal / coffee grounds/ but you need to start off right.... white or yellow sand.... white or gray portland...
Big Bob is offline   Reply With Quote
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 10:33 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
Is Structalite up for Tub-setting (instead of mortar?) House_Amuck Plumbing 2 03-20-2007 06:09 PM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 07:14 PM
