Master Bedroom Additon - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 02:38 PM   #1
Master bedroom additon
We are looking to add a master bedroom on the second floor of our home located in the Shenandoah valley. the addition would be 14 x 20 and buit on posts with the lowerlevel not enclosed. In additon to the room we would need to add a double sink in a 5 x 6 room in the corner of the addition and move a toilet in the existing house. We would also need to build about a 8 foot wall with a door in the existing house. Is $40,000 ($143 per ft^2) resonable for this additon.
rmac593 is offline   Reply With Quote
Old 10-13-2011, 03:19 PM   #2
Rewards Points: 5,336
Can't really tell over the internet. You would need to give plans to contractors who saw the site and were aware of the jobs characteristics.
Ron
B. Franklin 1759
Old 10-13-2011, 05:15 PM   #3
Msradell's Avatar
Rewards Points: 212
Your estimate sounds like it's probably in the ballpark but you need to get some local quotes to verify that. Just wondering, why aren't you enclosing the lower level. It will certainly make the addition much harder to heat and cool with nothing underneath it. It's even noticeable in rooms built over garages in many cases. Be sure to use very good insulation in the entire room for better temperature control, I would personally use closed cell spray foam insulation, it has a much higher R-value and completely prevents air infiltration as well as acting as a vapor barrier.
Msradell is offline   Reply With Quote
Master Bedroom very warm ks-man HVAC 34 11-03-2011 09:42 PM
Moving a master bathroom into a spare bedroom Vancouverbc Plumbing 0 03-21-2011 12:50 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Master bedroom placement near dining/living room EdieKay Remodeling 0 04-11-2010 06:48 PM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
