Mass Building Code/stair Risers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 11:34 AM   #1
mass building code/stair risers
what is the minimum height of the stair risers in massachusetts
brennanp is offline   Reply With Quote
Old 05-06-2013, 11:48 AM   #2
7-3/4 is the ideal rise. here is info on stairs. check with your local building inspector.
http://inspectapedia.com/Stairs/Stair_Risers.htm
The Following User Says Thank You to DannyT For This Useful Post:
brennanp (05-06-2013)
Old 05-06-2013, 11:50 AM   #3
Rewards Points: 502
Isn't it 8 1/4" maximum?
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
Old 05-06-2013, 11:54 AM   #4
Old School
Willie T's Avatar
Because Florida has so many old people, I have done more 6" rise stairs in the last ten or fifteen years than I can shake a stick at.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 05-06-2013, 12:17 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
in commercial structures the minimum riser height is 4-inches. in residential structures there is no minimum riser height. with that said I would never have less than 4-inches due to the fact anything less is a tripping hazard.
I am aware of Mass requirements as being a designer in Mass. here is the riser requirement for residential structures:
2009 IRC Code http://publicecodes.cyberregs.com/ic...9_3_par147.htm
Mass Amendments (changes above requirements) http://www.mass.gov/eopss/docs/dps/i...780-8th-51.pdf
post back with any questions.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Old 05-06-2013, 12:21 PM   #6
Rewards Points: 502
Didn't read it properly - thinking it was maximum!
Old 05-06-2013, 12:35 PM   #7
GBrackins's Avatar
you were correct on your "thinking" .....
Gary
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Staircase risers jeh Building & Construction 3 04-17-2012 09:45 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
