-   -   mass building code/stair risers (http://www.diychatroom.com/f19/mass-building-code-stair-risers-178914/)
brennanp 05-06-2013 10:34 AM
what is the minimum height of the stair risers in massachusetts
DannyT 05-06-2013 10:48 AM
7-3/4 is the ideal rise. here is info on stairs. check with your local building inspector.
http://inspectapedia.com/Stairs/Stair_Risers.htm
tony.g 05-06-2013 10:50 AM
Isn't it 8 1/4" maximum?
Willie T 05-06-2013 10:54 AM
Because Florida has so many old people, I have done more 6" rise stairs in the last ten or fifteen years than I can shake a stick at.
GBrackins 05-06-2013 11:17 AM
Welcome to the Forum!
in commercial structures the minimum riser height is 4-inches. in residential structures there is no minimum riser height. with that said I would never have less than 4-inches due to the fact anything less is a tripping hazard.
I am aware of Mass requirements as being a designer in Mass. here is the riser requirement for residential structures:
2009 IRC Code http://publicecodes.cyberregs.com/ic...9_3_par147.htm
Mass Amendments (changes above requirements) http://www.mass.gov/eopss/docs/dps/i...780-8th-51.pdf
post back with any questions.
tony.g 05-06-2013 11:21 AM
Didn't read it properly - thinking it was maximum!:confused1:
GBrackins 05-06-2013 11:35 AM
you were correct on your "thinking" ..... :thumbsup:
