#1 |
masonry mix for pointing 100 year old stone
I bought a 1909 house in central texas with a sandstone veneer . i have read I should use a soft mortar (lime and sand only ?) what would be the proper proportion for the mix?
#2 |
Usually about 2 or 3 sharp sand to one of lime and a bit of bit dust. Or use 3/1 3.5 NHL hydraulic lime/sharp sand.
| The Following User Says Thank You to stuart45 For This Useful Post: | kt82 (07-19-2011) |
#3 |
In 1909 in Central Texas, the chances are good that it is a portland mortar, although still soft. You should determine that first.
Advice is free, Lessons begin at 75 bucks an hour. |
| The Following User Says Thank You to Tscarborough For This Useful Post: | kt82 (07-19-2011) |
#4 |
You started using OPC in the mortar early on in Texas. Round here lime was still popular in the 30's.
#5 |
Alamo Cement was founded in 1880. There are 5 cement plants and 2 lime plants within a 100 mile radius of Austin.
#6 |
I wonder if the masons in 1909 worked if it was 100 degerees outside?? any of you around in 1909?
#7 |
masonry mix for pointing 100 year old stone |
#8 |
this series is really good. also i think he says what the material used was for repointing.
http://www.youtube.com/watch?v=bK9hoTebGj0 Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen |
| The Following User Says Thank You to Knucklez For This Useful Post: | kt82 (07-20-2011) |
| Display Modes | |
| Field Stone and Mortar Wall, will it be stable? | NorskeDiv | Landscaping & Lawn Care | 4 | 07-14-2011 11:18 AM |
| Real Stone Facing Dilemma | ydiy | Building & Construction | 6 | 06-26-2011 03:07 PM |
| Concrete Contractor and Masonry Contractor made a huge mistake | homeowner12 | Building & Construction | 19 | 07-07-2010 10:37 PM |
| J-Weep / Flashing for exterior cultured stone veneer wall. | Spud | Building & Construction | 18 | 08-31-2009 10:44 PM |
| Stone foundation for a small shack | andrgo | Building & Construction | 10 | 09-13-2007 02:49 PM |
