Masonry Help Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 02:27 PM   #1
Masonry Help Needed
Im going to install a stone veneer around the front and sides of my house from grade to approx 30". Part is over wood framing with tyvek and part is over existing foundation. Im familiar with most of the process although i have a few questions that i am unsure of.
Should the lathe cover the foundation or just from the sill plates up?
Is there a preferred brand/type mortar to use for scratch coat?
Can screws/washes be used for lathe or nails only? (of course galvanized)
Are there metal brackets to support stone ledger/sills?
thanks in advance
southshoreconst is offline   Reply With Quote
Old 10-23-2011, 08:46 AM   #2
Concrete & Masonry
Rewards Points: 548
Overlap over the foundation at least a few inches.
Brand no, but Type S is the prefered plaster mortar.
Yes, no problem as long as they're galvanized.
I've never seen metal made just for for this, but they do make a few different sized/styles of plastic "weep screed" fro EIFS that would work. You can also just purchase 1x1 angle iron, or even larger, and drill & mount yourself. Galvanized would be a good option here as well, if you can locate it.
thanks in advance
Best of luck.
jomama45 is offline   Reply With Quote
Old 10-23-2011, 07:47 PM   #3
thanks Jomama!
How long can i leave a scratch coat up before actually applying stone? if i was to do it next month could it wait till spring before i apply stone or would it be better off to just do scratch coat then?
Thanks again
Old 10-23-2011, 08:20 PM   #4
Concrete & Masonry
Rewards Points: 548
You can leave it up over winter w/o an issue, you may just need to rinse it clean in Spring. We generally scratchcoat with a small v-notch or 3/16" notched tile trowel as well for additional adhesion, with the "notches/grooves" being horizontal.
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 01:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 07:56 AM
I need a very very high quality masonry bit - Help Needed badly. MooseWoodworks Tools 5 03-13-2011 08:28 PM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 10:53 AM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 10:17 PM
