-   -   Masonry drilling (http://www.diychatroom.com/f19/masonry-drilling-4434/)
stenton 10-22-2006 04:50 AM
Masonry drilling
Hi,
Probably a dumb question but I am trying to put up curtains in my kid's room using a masonry drill bit and have got stuck about 1.5cms into the wall - there is a stone in the concrete or something - it keeps blunting my drill bit so what do I do to break through?
AtlanticWBConst. 10-22-2006 06:21 PM
Originally Posted by stenton (Post 21465)
Hi,
There is a possibility that you hit piece of steel 're-bar' imbedded in the concrete.
Only other option is to move the anchoring location up or down in order to avoid the rebar and hit a concrete-only area.
That has been my experience when my masonry bit does what, you say yours is doing.
Good luck
mdshunk 10-22-2006 06:24 PM
Are you using a hammer drill? If you're using an ordinary drill with a masonry bit, it will often stop cold at a stone. Might also be a rebar, but I sorta doubt it. I hope that any rebar is more than 1.5cm deep (that's only around 3/4 of an inch).
stenton 10-23-2006 01:01 PM
Hammer drill doesn't work either. Thanks anyway.
stenton 10-23-2006 01:02 PM
Is a re-bar a rigid steel joint/joist (RSJ here in Europe) and if so how far should I move the anchoring location? And do I move it up or down or sideways?
concretemasonry 10-23-2006 01:31 PM
Masonry drilling
stenton -
Do you know what material the wall is made of?
Possibilities are:
Poured in place concrete (in situ)
Precast concrete
Concrete block
Clay tile
If it is precast concrete, the steel re-bar could be closer to the surface than poured in place concrete because of the standards for interior walls and the greater accuracy possible in European factory settings.
If it is a steel rebar (usually 8mm to 14mm) you should try about 25 or 30 mm to the side. If that is not good, try a spot about 25 or 30 mm above or below.
It is very highly unlikely, but you may have precast concrete panels with embedded steel weld plates for connecting panels. This type of construction usually plastered for a fine finish. - What country are you in? Eastern Europe possibly?
troubleseeker 10-25-2006 10:21 PM
Possibility of rebar, but I doubt it. Sounds like you have just encountered a rock in the concrete.They will eat up typical hardware store masonry bits, especially if you are using a regular drill or a hammer drill, which drills more than hammers. If you can borrow or rent a small rotary hammer, the much stronger hammer action, coupled with the "precussion" rated bit will usually make short work of the rock.
KUIPORNG 10-26-2006 09:42 AM
this is strange, you mean your home build solely by concrete, no wood... or drywall?.... normally, curtain hang on wood studs...etc.
concretemasonry 10-26-2006 12:58 PM
Masonry drilling
KU****G -
Wood construction is in the minoity.
Most residential construction in the developed world is
NOT wood. Wood is the most common residential building material in North America and many undeveloped tropical areas. In the devloped tropical areas, concrete (precast and poured in place) and masonry (brick, concrete and AAC) are used.
KUIPORNG 10-26-2006 01:30 PM
You mean North America is undeveloped.... that may be true... compare Canada with Asia, we kind of 10 years behind I guess....
I think it is climate has a contributing factor to the material decision as well...
concretemasonry 10-26-2006 03:33 PM
Masonry drilling
I did not say North America was undeveloped. I just pointed out that it was a part of the developed world that uses wood for residential construction. In North America, they had to cut down trees just to build. they tradition continued because there were no brick or concrete plants for quite some time.
much of Europe prefers non-wood construction because of fire resistance, sound, rigidity and permanence. China prefers concrete/masonry over wood because of because of image, fire, and permanence. Russia/Siberia uses concrete (mainly precast) in towns and cities, but wood where you are far from town of over 200,00- or so. The economic concrete/masonry advantage is a no-brainer in countries where they consider a longer life in a building. Their sophisicated thermal anaysis shows the advantage of heavyweight construction over the "advertising-oriented" lightweight construction materials like fiberglass and gypsum, but they do use some extruded polystyrene foam.
The warm climates have an abundance of wood for the outlying areas, but concrete or masonry in the cities because of the type of construction. You are right about the climate since places like the Carribbean, Spain, Turkey, Greece, the Middle East and India prefer the benefits of mass for temperature moderation, which decreases energy use.
We are not underdeveloped in design and construction, but just have different needs and standards. There are some very advanced areas such as Brazil where they routinely build 15 to 20 story apartments out of 6" thick block wall with no steel or concrete columns. They essentially use our standards, but know how to use them better.
What has to do with drilling? - I was trying to find out what kind of wall construction the person had. Not everyone on the forum is from the U.S., so we all have different problems.
KUIPORNG 10-26-2006 04:12 PM
Thank you for the detail information.... I do like the nature feeling of wood though... as I have a feeling wood may look not as strong as concrete, may be that is true for the first hundred years, but after hundred years, things may start to change, it in fact, may last longer... a wood built temple in China built hundreds/thousands years ago may still stand there rigidly... but concrete built building generally require a lot of maintenance over time due to cracks and fall out pieces......
concretemasonry 10-26-2006 04:32 PM
KUI****G
Ever heard of the Great Wall of China? There is was little maintenance done, but I would think a temple would get looked after.
I showed a group of Russia/Siberian engineers through a $650,000 log model home. - They asked why somebody would build out of "firewood". That is just the way they look at things and don't worry about hanging pictures.
You have to hunt to find a fire truck in much of Russia. - Not to many concrete ready-mix trucks either since most concrete is precast (including footings).
yummy mummy 10-29-2006 02:35 PM
concretemasonry
Boy, did I learn a lot today about construction materials in different parts of the world.
I'm in Canada and I have only heard of what Kui****g has heard of.
How narrowed minded I am.
stenton 12-04-2006 12:16 PM
Originally Posted by concretemasonry (Post 21609)
stenton -
Possibilities are:
Precast concrete
Concrete block
Clay tile
Yup. East Germany. I think it was a bit of steel. In the end I just relocated a couple of cms. Looks crap but hey the curtains are up!
