Masonry Drill Speed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 05:37 PM   #1
Rewards Points: 948
masonry drill speed?
I need to drill some 1/4 and 7/8" holes in 4in concrete blocks using a36v hammer drill. I have a cheap 1/4 bit and an expensive 7/8.
What speeds are best?
I drilled a 7/8 first and was surprised a how easy it was on slow. I then did a 1/4 and it wouldn,t drill at all. I incrased the speed and it improved dramatically. I don't know how good it was for the bit, but I did the other 5 holes on high. Was that right?
I have 6 7/8 to drill. What speed do I use?
Toller is offline   Reply With Quote
Old 06-14-2013, 06:02 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 832
Most good rotary hammers (i.e. not the ones that are on standard drills) are low speed rotationally and good on the vertical hammer action.
If you go too fast on the common 3 and 1 drills, the hammer is more like noise than a true deliverable of force.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Willie T (06-14-2013), woodworkbykirk (06-14-2013)
Old 06-14-2013, 07:57 PM   #3
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
You don't want to run the bits at any fast speed- they'll get hot very fast and that's the end of them, slow and steady is the best speed.
RWolff is offline   Reply With Quote
Old 06-14-2013, 08:01 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,324
Keep them wet..... I usually just take a plastic milk bottle... punch a hole in the bottom.... and let it "pee" on the bit
Seems different substances like different drill speeds.... I guess that my Boshe Bulldog and most all drills are variable speed.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Should have bought a hammer drill Ultrarunner2017 Concrete, Stone & Masonry 5 03-17-2012 12:07 AM
Fujitsu Ductless AC "Fan only" speed problem? chiefswabjockey HVAC 0 03-07-2012 11:21 AM
Help me choose a power drill morph999 General DIY Discussions 18 06-17-2010 08:17 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 02:46 AM
