Masonite Siding Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 10:30 AM   #1
Where can I find replacement siding for Masonite 3 in 12 lap siding with smooth surface?
carlocases is offline   Reply With Quote
Old 08-01-2011, 10:39 AM   #2
Rewards Points: 150
You will have to switch to Hardi, Masonite doesn't exist because it was so bad. Home depot has Hardi.
Broughton is offline   Reply With Quote
Old 08-01-2011, 10:50 AM   #3
kwikfishron's Avatar
Rewards Points: 998
Welcome to the forum.
Your local lumber yard should be able to order it for you. Mine stocks the 12” smooth but not the T4.
kwikfishron is online now   Reply With Quote
Old 08-01-2011, 10:54 AM   #4
Rewards Points: 150
I apologize, glad you were here kwifishron. I thought Masonite was out of existence.
Old 08-01-2011, 11:04 AM   #5
Masonite replacement
Thanks for the prompt response. I'm sorta way past the regular options on this one. I'm trying to find an exact match for the 3 in 12 lap pattern with a smooth surface. So far, even my wholesale warehouses in my area aren't much help with the smooth aspect. It's a bay window on a large project with quite a bit of existing siding that still looks great.
Masonite Siding Repair kennykenny Carpentry 6 04-07-2011 07:48 PM
Masonite Siding Replacement kennykenny Remodeling 2 07-20-2010 04:52 PM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 08:57 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
