Old 11-02-2006, 11:28 AM   #1
masonary problems...
i had a gutter that leaked on my brick home during the end of last winter, i fixed the gutter, but the brick had absorbed enough water to mildew during the spring. and even grew moss. i want to fix it but have no idea where to start? The water also soaked through the wall and cause cracking in the paint inside. I know that it is a solid masonary wall, so my main concerns are drying the walls out, repairing the damage inside ande the mossy grout outside, but i would like to prevent this from happening again or anywhere else on my home. what do i do?
fatbob79 is offline   Reply With Quote
Old 11-02-2006, 11:58 AM   #2
concretemasonry's Avatar
Is the paint inside on the brick itself? - No wood, plaster or gypsum board in the wall?
concretemasonry is offline   Reply With Quote
Old 11-02-2006, 11:06 PM   #3
it appears to be cement. the home was built in 1940. I tapped it with a hammer and it is pretty solid as though it is solid cement, so i am not sure if that will help you at all but i hope so.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 03:10 PM
