Marvin Sillguard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 06:36 AM   #1
Marvin Sillguard
Looking for comments about a product from Marvin called Sillguard. Is it worth the expense over conventional tape products? Also I read a press release that advised against using for recessed masonry applications. I have 2 x 6 construction with brick exterior. Does this mean I shouldn't use a Sillguard for the windows I'm about to replace? If so why?
david.plymouth is offline   Reply With Quote
Old 08-16-2009, 07:00 AM   #2
I have never used it but I would say it is much better than tape. There are other similar products available, including metal and composite wraps that do the same thing. Marvin makes good products, but at a price. Check at a local lumber yard that sells doors(not big box), for alternatives. You definitly need something under that door to prevent wood damage from leaks.
Old 08-16-2009, 07:10 AM   #3
Remodeling Contractor
with a brick exterior you should use lead flashing which you get at your local masonry supply store. A gap of 3/16" around the windows is left to provide adequate space for caulking.
Old 08-16-2009, 07:36 PM   #4
lead, are you serious. Who uses lead these days!!
Old 08-16-2009, 07:44 PM   #5
My chimney was rebuilt not too long ago & flashed with lead
Old 08-17-2009, 11:29 AM   #6
I used 3 X 3 metal headers and lead flashing. Maybe you do cheap jobs, but most of mine are over $100,000 and short cuts are not allowed.
Andersen Vs. Marvin segercasey Windows and Doors 36 09-12-2011 05:37 AM
MARVIN & MILGUARD Windows? What Brand To Get? MGJIM Remodeling 5 08-05-2010 09:09 AM
