Making Tile Shower Opening Larger To Fit Glass Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 01:22 PM   #1
making tile shower opening larger to fit glass door
i have a tile shower and want to renovate it to make the opening larger to insert a glass door. how do i go about removing the tile wall and putting in new frame?
12gloria is offline   Reply With Quote
Old 11-22-2010, 03:47 PM   #2
Rewards Points: 5,332
Hammer, chisel, prybar and garbage bags.
Most times you gut the bath or leave it alone unless you have enough spare tiles to redo the "demoed" section.
Ron
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 05:37 PM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 08:26 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
