Making Space Amongst Existing Roof Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 11:18 PM   #1
Making space amongst existing roof trusses
I am installing ducted air conditioning but there is not enough space amongst the trusses for the FCU to fit. I need to remove (modify) the 2 centre braces to make space. The trusses are 550mm spacing and the roof is 17 1/2 degree. Is this a feasible idea?
davidhaine is offline   Reply With Quote
Old 10-26-2011, 01:07 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,482
What country do you live in?
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 10-26-2011, 06:37 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Modifying a roof truss is a bad idea. All of a trusses components are mutually dependent on each other and work as a system. Wrongly changing one piece renders the entire truss useless. You need an engineer to tell you where and how you can modify it. Hopefully one who designs roof trusses.
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing/Siding 19 10-08-2010 12:17 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 08:47 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
