Making A Mini Door On A Rough Block Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 05:24 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Making a mini door on a rough block opening
I have an opening in a block wall that is semi square but very rough. What is the best way to go about making a door frame around that? I'm thinking some 2x8's for the inside, and just cut them so they are very tightly fitted, and add shimming to make it fit tightly, then some 2x4 around just to "finish" it and also to tapcon it to the block. Is there a better way I'm not thinking of?
Oh and that pipe is just for the central vac. If it gets in the way (which it probably will) I'll just cut it. I'm guessing it was done that way just to dampen the noise, and to add a bit of heat in there while the vac is being used.
Old 02-25-2011, 07:01 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Red, If the 'door' is to be used very infrequently then could just cover the opening with a sheet of plywood secured in place with a couple of blue Tapcons.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-26-2011, 01:31 PM   #3
Rewards Points: 5,336
If you want to put a frame in there, you'll need to clean up the opening. A grinder and a chisel will do the job. If you want the frame to span the entire block wall you'll need to rip down a 2x10. If not, a 2x8 set to the camera side will do fine.
Ron
Old 02-27-2011, 06:41 PM   #4
Wire Chewer
Rewards Points: 90
I have a chisel already, I'll look into a grinder and clean it up a bit then go from there. And yeah 2x10 might be better. I did not actually measure yet but more I think about it, 2x6 would probably not be wide enough. I'll probably caulk around the frame and try to make it look half decent. The door itself will probably have a screen. The idea is to keep bugs out but still remain some air circulation. Though now that I got it spray foamed bugs probably won't really be a problem anymore.
Odd sized existing rough opening in interior door. t_mott85 Remodeling 2 11-24-2010 11:56 AM
making tile shower opening larger to fit glass door 12gloria Building & Construction 1 11-22-2010 03:47 PM
Rough opening for bi-fold doors DCCook Building & Construction 6 03-20-2009 09:25 PM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 12:00 PM
