-   -   Making a load bearing wall a half wall (http://www.diychatroom.com/f19/making-load-bearing-wall-half-wall-42172/)
vjbozard 04-10-2009 11:05 AM
We are remodeling our kitchen and want to do a small 1/2 wall on both sides of the doorway leading into our dining room. I know that standard cabinets are 34 1/2" then the counter top. But I thought that the wall should continue up past the counter top for a small ways then be topped off with some nice wood & a post next to each walkway for support. How tall should the top of the wall be ? Thanks!:wink:
Kitchen layout:
http://i152.photobucket.com/albums/s.../kitchen-8.jpg
Halfwall layout:
http://i152.photobucket.com/albums/s...5/halfwall.jpg
Gary in WA 04-10-2009 01:55 PM
You can go what ever you want . Put some blue tape across the wall over the existing cabinets to get a visual idea, 40"-44". Keep in mind electrical outlets required every 4' on counter tops. The elec. box nails vertically or horizontally, but figure 2 top plates and a 4"box plus 1-1/2" over finished counter top. Or 2-1/4, plus 1-1/2" (box on side). Is your dishwasher to the right of the sink, in that 24" space? Think about when it's open, no passage at that time., if that's an opening. Also, where are the glasses going, uppers on other side of sink? Pot-filler at stove because sink is so far away? Be safe, GBAR
vjbozard 04-10-2009 03:08 PM
If I have a 123" wall, how many outlets do I need & what would the spacing be?
concretemasonry 04-10-2009 05:29 PM
vj -
The code is a minimum and probably will not be enough for the real world now or in the future. Don't short yourself when you have everything apart and are putting it back together.
Gary in WA 04-10-2009 06:56 PM
There is a lot to electrical. There is a special rule for: 2-20amp.small-appl.ckt req.; outlets within certain distance of sink; rules for refer; dishwasher; disposal; counters12" and over; spacing so no point over 24" cord reaches; GFCI required; special island requirments; and other special circumstances. Ask on our electrical forum.So it depends on what's in the countertop. Be safe, GBAR
Gary in WA 04-10-2009 08:18 PM
Here are two sites that cover the basics:
http://www.electrical.state.ne.us/homeowner.pdf
http://www.lowesforpros.com/a-well-wired-kitchen
Be safe, GBAR
Wildie 04-11-2009 06:50 PM
I would suggest that the dish washer would be moved over between the sink and the refrigerator! Having its door open in a passage way is not a good idea!
Rather than open up the wall, I would put in a pass-through.
Kitchens are noisy, and its nice to be able to close them off.
Joe Carola 04-12-2009 08:34 AM
1 Attachment(s)
Kitchen layout:
Halfwall layout:
There's no mention of the two headers you have to put in on each side of the existing door header. You can use the existing king stud as the king stud for the two headers and put a jack stud underneath the new header on each side of the existing door header and the other sides you will have to put a king and jack stud.
LawnGuyLandSparky 04-12-2009 02:27 PM
2 Attachment(s)
I suggest you put a 24" wide floor to ceiling pantry somewhere in there. Instead of a 36" caddy-corner or neo-angle base cabinet, use a 36" x 36" lazy-susan they hold a helluva lot of pots and pans and everything is accessible. For receptacles do what I did to every outlet in the house (practically.) I turned them all into this...
Gary in WA 04-12-2009 03:11 PM
Ever get any static on the phone when the cat5 is within 6" of recepts? Be safe, GBAR
